Home > Faults & Fixes > 2.7 2005 rrs smoking
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Hi All, noticed today that the car smokes terribly when sat idle. Now its always smoked on idle but nowhere near as bad as this. It also smokes whilst driving but nowhere near as bad. Been like this for a few month but we have hardly used it as its a backup car, Hard to say if its White or Blue or not but it has a smell to it that i can't describe. Im not losing water and there's no loss of power etc.
Ive had a look at the oil tonight and that seems fine, I have also noticed tonight that the turbo-intercooler pipe on the right hand side doesnt seem to be in correctly. You can see the O-ring and the plastic pipe is loose. Tried to pull it back together but it just pulls apart Big Cry. Is this the likely cause and should there be a clip holding it in?
Post #601992 Mon Jul 20 2020 9:35pm
looneyfitter
So the connection in the MAF sensor side where the preformed plastic ducting connects on the right hand side behind the fan so its probably the turbo air intake and not the intercooler pipe?.
Post #601993 Mon Jul 20 2020 9:58pm
A leak in the inlet ducting will cause smoking because it results in overfuelling. Fix the pipe and you should solve the smoking. 2012 SDV6 - it's missing a couple of cylinders
Post #601994 Mon Jul 20 2020 10:33pm
looneyfitter
Cheers mate. What holds the pipe on?
Post #601995 Mon Jul 20 2020 10:45pm
The pipe snaps together.
You need to support the lower Pipe with one hand and push the top pipe on.
Put a bit of wd40 round the seal first to help it
Post #602101 Fri Jul 24 2020 6:58am
