Home > General > 2007 tdv8 oil recommendations
Johnsurrey
I’m sure it’s been asked before but what engine oils best for a 2007 tdv8, it’s going to be a between services oil change so was going to suck the oil out of the dipstick and wait till the full service to change the filter
Post #601869 Thu Jul 16 2020 10:45pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
For the TDV8 5W-30 WSS-M2C913-C the spec you need. I've been using Shell Helix.
Personally I would always drain the oil from the sump rather than try the suck out the top approach on the TDV8 (which I think is more relevant to the later 3.0 engines). Don't forget to purchase two new sump plugs (circa £2/ea) as most filter kits only come with the one and even though only a relatively small amount drains from the secondary one I always drop both plugs including my interim oil changes to avoid any sludge build up. I also change the filter every time (6k/6months) as it can only be a good thing, especially as the filter is only a tenner and you'll be spending at least £40 on oil!
You'll need 9.5 litres but I generally refill with 9 then run the engine for a minute or two then top up as per the dipstick. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #602214 Sat Jul 25 2020 9:50pm
Dixie Dean
Lots of people with D3 2.7 cars saying 5W 40 C3 is now better, and to change it every 6K to 7.5K to ensure bearings don't go early.
Post #632153 Wed Apr 05 2023 3:43pm
Disco_Mikey
Lots of people saying 5W40 is better, with no testing or technical information, other than a higher HTHS rating (which is largely irrelevant due to the temperatures involved)
JLR, Peugeot, Citroen and Ford all state 5W30...
Post #632158 Wed Apr 05 2023 7:52pm
Dixie Dean
So which particular oil are you using Disco_Mickey?
Post #632164 Wed Apr 05 2023 9:26pm
Disco_Mikey
Comma Ecolife previously, but moved to Quantum Synta C1 now. Both 5W30
Post #632166 Wed Apr 05 2023 9:43pm
Jabba
Mikey,
Would Quantum Syntra-Z 5w30 be ok to use with a 3.6 tdv8. I read the spec for C1 which seems to be for dpf models.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632335 Fri Apr 14 2023 12:33pm
