![]() | Home > General (L494) > Dashcam in P400e - front and rear |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
Ive installed a Tornado hardwire battery monitor kit for my front and rear goluk dash cams.
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 109 ![]() ![]() ![]() |
some good videos on you tube, thinking of doing the same thing, just ordered my P400e for delivery sept, been do a little research on front and rear hardwired cameras, front no problem but rear if you want a neat job the rear spoiler needs to come off for this else attach to the rear head lining, so i might forget the rear,
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Got the wiring plumbed in on Sunday. No issues getting it in the headliner and door trim. When it comes to the rear tailgate, there is a small section of wire seen.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
Can't say if they are the best fuses to use, but are you sure one is a permanent live and the other ignition live? I can't really remember but I have a vague recollection the yellow is live and red aux but that may be on the thinkware as though at the time the red would be the permanent live for some reason.
Thanks Col,
ashie2 Member Since: 16 Jul 2020 Location: Cheshire Posts: 2 ![]() ![]() |
@Pakolainen Did you manage to find the correct fuses to hardwire the cam? I'm having a similar problem as I can't seem to find the correct combination of fuses for constant power and non-constant power.
No joy so far. I'm getting no power to the Power Magic Pro.
