Home > General (L494) > Airbag compatibility
00by
I think I know the answer to this, but may as well ask the question!
I believe in the attached photo the top airbag is an early dual stage design and the bottom is a later single stage design.
I'm assuming they are NOT compatible - that is even if you change the clock spring to the correct wiring the car programming will not work properly with it and it's a complete no go.
If anyone knows any different do share...!
 MY16 RRS 3.0 SDV6 HSE Dynamic
Post #601325 Sun Jul 05 2020 11:13am
