![]() | Home > General (L494) > Water ingress in boot |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Is there water in the boot? Has it got in past the seal? Otherwise it's probably water running along the underside of the edge until it finds the boot stop. Also, any external plastic trim will catch water which then runs out when the boot is opened. 2012 SDV6 - it's missing a couple of cylinders
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
no water in the boot at all, i'd expect some run off from the doors etc but it's not just a small drip, literally pours out for a second or two when the boot opens so it's pooling somewhere.
pc1972 Member Since: 30 Aug 2012 Location: scotland Posts: 38 ![]() ![]() |
Hi thegoodwillout , I have this problem as well, I’ve unscrewed the rubber stopper a bit to help the water out, please keep us posted to what lr say 👍 |
Car back from dealers yesterday, there was, as suspected, a leak through the boot trim which was pooling water in the boot door itself. Old trim removed and a new trim added.
Hitman 1979 Member Since: 23 Aug 2017 Location: Uk Posts: 1 ![]() |
Hi all, do you know which parts of the boot trim were replaced/ allowing water to ingress to occur. I have had the same problem too recently and after heavy rain for a prolonged period of time (heavy downpoor for several hours a few weeks ago ) i had small gush of water come out of the latch and around the electronic boot close butto when opening the boot
teldec Member Since: 29 Dec 2019 Location: essex Posts: 80 ![]() ![]() |
i took the tailgate trim off and cleaned it thoroughly, also cleaned the tailgate area as that was thick grime, added a few blobs of silicone to the clips before refitting and it seems to have done the job |
Kidneywiper Member Since: 07 Feb 2011 Location: England. Posts: 16 ![]() |
Which trim are you referring to please ?? |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
Had exactly the same issue and my local LR indie told me to take off the rear number plate. This revealed 2 or 3 random holes in the metal behind the plate which I taped over with duct tape and it’s never leaked since.
B10WGB Member Since: 19 Aug 2024 Location: Essex Posts: 1 ![]() ![]() |
Had this exact problem today for the first time. A waterfall coming out of the latch. Is there any good breakdown videos showing how to remove the boot trim so I can try and fix myself or at least diagnose it?
&t=284s |
