Home > Maintenance & Modifications > Location of sump plug 2013 3.0l - last of the old style
Scoie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HST Firenze Red
I have had a search so I am sorry if this has been posted elsewhere already - I am new to the site! My question: I want to do an interim oil/filter change between services on my 3.0l diesel 2013 last of the old style (its a Black edition and rather nice) and I know this sounds crazy but I cannot find anywhere information about where the sump plug is located! My usual garage is not answering the phone.. can anyone help please? Thank you in advance!
Post #600387 Wed Jun 17 2020 3:43pm
well you remove the massive heavy engine guard.
you should then see a small black sump like a 5 litre bottle. and a 13mm? bolt on the bottom
Post #600390 Wed Jun 17 2020 4:33pm
Don't know if there is a shortcut, but a bit of a performance to reset the oil level indicator on the dash according to the manual, not like the old days pour it in and check the dipstick. Laughing
Post #600406 Wed Jun 17 2020 9:28pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Changing the oil by removing the sump plug is fine but a real PITA. if you intend to change your oil every 6 months as I do then invest in a vacuum pump and suck it out the breather on the left side of the engine. It’s the pipe sticking up in the 7 o’clock position relative to tHe oil filler cap.
Oil filter and oil change takes about 15 minutes, 10 of which are drinking you tea. It also gets ALL of the old oil out
As for resetting the oil level indicator - there is no reset required. Drain the oil then put in 6 litres of fresh oil, warm up the engine To normal running temp, wait 10 minutes and check the level
Amazon has loads of vacuum pumps, Sealey make a good 6.5 ltr one, just make sure it will hold at least 6 litres.
Post #600444 Thu Jun 18 2020 3:24pm
Not quite sure why L/R would include nearly a 10 page section in the workshop manual telling you how to do it using a combination of the the c/c and menu buttons after doing a oil change if not required, unless I've misread it which is quite possible, or it's just L/R complicating thinks as usual.
Post #600466 Thu Jun 18 2020 9:14pm
LandPhil
I can’t help with that Col but I have done about 6 oil changes on my 2013 Black and never done a reset and everything works just fine.
Post #600469 Thu Jun 18 2020 9:32pm
LandPhil
Just had a thought - is it telling you to reset the Service Required warning which I think includes the Oil Dilution warning, which I have never seen in my RRS.
Post #600473 Thu Jun 18 2020 9:37pm
I just wonder if it isn't reset afterwards whether it is showing a totally accurate reading, but if you refill with the correct amount and haven't had any issues I guess it can't be far out. No it doesn't mention the DPF or reset service indicator, not sure the RRS1 3.0 had oil dilution issues did it?
Post #600474 Thu Jun 18 2020 9:40pm
knwatkins
The oil service reset does impact how the car performs a DPF regeneration.
This is stated in the IID tool manual...
DPF regeneration will always cause engine oil dilution to some extent through overfuelling into the cylinders where small amounts of fuel will pass by the piston rings.
The only time it's a problem is when the regeneration process is being conducted at much more regular frequency than desired, causing excessive dilution. Kev
Post #600484 Fri Jun 19 2020 7:27am
Are we not talking about two slightly different things here.
Post #600487 Fri Jun 19 2020 7:37am
knwatkins
Ah, yes, sorry Col, my bad. Kev
Post #600488 Fri Jun 19 2020 7:39am
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I've got the same car one of the very last of the old models and this was my plan every year staggered 6 months with the Indy service. However, this has an electronic oil level indicator through the menus so no dipstick. Anyone know how to do a top end change on these? L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #600504 Fri Jun 19 2020 9:40am
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Simples says L/R, make it sound complicated baked up with lots of pictures and pages and there you go they say.
Driver/customer, this sounds hard and complicated i will take it to L/R and pay them to do it and thank them for emptying my pockets.
Synical who me never. Rolling Eyes
Post #600508 Fri Jun 19 2020 10:05am
abiopete
Ignore that, found it.
Post #600513 Fri Jun 19 2020 10:59am
