Home > Faults & Fixes > Gearbox F but only when reversing
Nico2104
Hi, I'm hoping someone can help me or point me in the right direction, basically sometimes when reversing the dreaded F comes up on the dash, it still reverses but once put into park it doesn't come back out until I've switched the car off and back on, I have found it does it more often if reversing up a hill, I have had it to the garage and all that came up on the diagnostic was the park/neutral switch but since they cleared that it hasn't come back up even though the dreaded F still comes up and it sticks in park once the F is showing. Any help would be appreciated, cheers
Post #599273 Mon May 25 2020 4:14pm
Nico2104
Sorry I forgot to mention it's a 2006 sport, 2.7 tdv6
Post #599274 Mon May 25 2020 4:15pm
Terryok
Check gearbox fluid levels !!
Post #599353 Thu May 28 2020 11:54am
Nico2104
Abit of an update, gearbox oil has been checked and is the level it should be, garage is baffled as no faults other than a high voltage fault showing, really stuck on this one so if anyone has any ideas it would be appreciated. Cheers
Post #600829 Fri Jun 26 2020 8:53am
knwatkins
I'm not able to help on this, but it may also be worth posting on the Disco forum in case anyone has come across this previously. Kev
Post #600831 Fri Jun 26 2020 9:14am
