Home > General > RRS 06 TDV6 Suspension Dropping Overnight - Help Urgent :(
Fiorano
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Bonatti Grey
Hi
So.. my O6 RRS keeps dropping very low overnight though not to the bump stops.
I've had new bags put in recently but still the same issue.
Yesterday, I removed the EAS fuse in the engine bay and today the left side is around access height but the right is very low.
When I start the car, it's fine. It pumps right up and there are no HDC faults showing. The compressor doesn't appear to be constantly working.
I suspect its the Solenoid blocks so I plan to get the garage to remove them and clean them out with petroleum jelly. I can't get new seals or parts just yet as I have a long trip home on Monday and no-one is delivering ((((
Any thoughts guys on what else I should do/check.
Much appreciated
Post #599263 Mon May 25 2020 1:01pm
Valve blocks or air leak in a pipe. As it's both sides, that would suggest that the valve blocks have junk in them, probably desiccant from the air dryer in the compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #599264 Mon May 25 2020 1:49pm
DEVON
Had the same issue , stripped and cleaned out the valve blocks (rear one was a pain)
But been fine ever since Thumbs Up
Post #599267 Mon May 25 2020 2:13pm
Fiorano
Thanks guys!
That's the plan for tomorrow - I'll get the garage to strip and clean all 3 Thumbs Up
Post #599268 Mon May 25 2020 2:15pm
I don't think you use petroleum jelly. Water is fine to get ride of white power.
Why don't you want till your home?
Post #599270 Mon May 25 2020 3:22pm
Fiorano
I read somewhere that you use petroleum jelly.
I'll just clean them without using anything.
I'm travelling to Italy (Home) but I trust my garage here rather than there Crying or Very sad
Post #599282 Mon May 25 2020 5:53pm
Fiorano
Currently sitting at the garage.
I've had all the major work done:
Front/rear belts
Oil pump
Water pump
Alternator
Pulleys
Gearbox oil service
Engine oil service
Coolant flush
New A/C parts
Now it's just the suspension Sad(
Post #599283 Mon May 25 2020 6:02pm
