Home > In Car Electronics > More head unit replacement issues....sorry!
Fire1
I fitted a full incartec kit and pioneer head unit on my 06 with Logic 7.
Couple of hiccups as expected but nothing major.
System all seems to work except!! The front speakers don’t work they just hiss, even when I turn ignition on and head unit is powering up the fronts are just hissing.
So far I have
Checked all plugs throughout the install and all appears ok
Checked the balance on the head unit and it’s equal front to back.
I am not an expert at all with audio I just followed the instructions along with some very helpful advice with forum members so thank you.
Is there anything anyone thinks I could try or do now? Like I say no expert. Thank all.
Post #599223 Sun May 24 2020 10:26am
I would try the head unit in another car if you can. (Not landrover)
Post #599226 Sun May 24 2020 11:15am
Fire1
Oh yeah? Is it a possibility the unit could be faulty you think?
Post #599228 Sun May 24 2020 11:41am
Possibly.
Isn’t is only cables between the speakers and headunit ?
Or do the speaker wires go thru a box
Post #599230 Sun May 24 2020 1:02pm
Fire1
They go through the amp I believe well from what I’ve read?
Therefore it’s all on the multi plug
Post #599231 Sun May 24 2020 1:28pm
The landrover amp ?
I don't think so. If you are unplugging the connector with all the green wires from the amp and plugging it into the accessory loom, it's not going thru the LR amp
Post #599239 Sun May 24 2020 4:33pm
Scrumpy
If I remember correctly when I did mine, the new head unit powers all the speakers (using the Incarteck loom) and the additional amp is just for the sub woofer in the boot. 2016 RRS SVR Estoril Blue
Post #599323 Tue May 26 2020 8:56pm
JCVD
New Zealand 2006 Range Rover Sport Supercharged Java Black
I have the exact same issue as the Op after installing the incartec kit. does anyone else have any input or experience with this problem?
Any help greatly appreciated.
Post #606709 Wed Nov 18 2020 12:54am
