![]() | Home > My Range Rover Sport > RRS 2016 Autobiography Dyn L494 SDV6 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Best way to keep it happy is to find a decent indy to look after it -avoid main dealers at all costs. And drive it. These things don't like to be used for short journeys. Get it warmed through properly and give a decent run. The DPF will be happier for one thing. Also, give everything a bit of use on a regular basis, even if it don't use it normally e.g. engage low range and drive it to and fro, use the full height range on the suspension, use the EPB, etc. 2012 SDV6 - it's missing a couple of cylinders
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
You can get iPad holders for the seat backs, may be a better option than trying to build anything in.
FrankH Member Since: 21 Mar 2017 Location: Crawley Posts: 23 ![]() ![]() ![]() |
Sounds like good advice to use all the functions on a regular basis, something I have not been doing, will start doing this from now on. Thanks 2015 SDV6 306bhp Dynamic santorini black. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
As a general rule because the RRS is hers when I drive it I tend to raise the suspension to off road height as I drive off the drive and then let it drop back down when up to speed and I tend to drop it access height every other time I park it on the drive
therealchrisgm Member Since: 06 May 2020 Location: liverpool Posts: 21 ![]() ![]() ![]() |
Thanks really good insight there and totally understand! Have owned a LR Disco sport before which wasn't the best so hoping this is an improvement! |
