![]() | Home > Technical > Engine ECU replacement |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
1 it’s your cheapest option
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
Thanks Andy, yes I forgot about the clocks |
Best to ask gap. They are very helpful. |
Just been talking with Bell Autos and he said the same thing, special files required so I’ve emailed Gap. Could justify the cost of the tool and a useful thing to have going forward.
Ideally, you need a full set if modules that work on the HS CAN network
Heard back from Gap and my ecu type can’t be recoded from the tool only a new ecu can be done. I’m just hoping someone can read the codes from my ecu? I’m loosing confidence in the place that has it at the moment.
Hi Mike, are you saying it’s not just a case of buying a matched set of modules then? Can’t catch a break ![]() Steve Steve 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, mothballed future project. 1999 BMW Z3 (owned from new) garage queen. |
I think for around £250 a module set is worth a go.
I’ve looked at few sets and should I be concerned about the gauges? One set the temperature gauge wasn’t at zero and another the speedo showed 20mph. If their coded and faulty am I into another world of trouble?
Dunno. Probably ok.
I would go the ecu set route if if there was any information that it would work, nobody seems to of do it here or on Disc3. Steve
We don't do it because:
That’s all very well Mike but I don’t know what you mean? Steve
I had a D3 in for a new transfer case module
