Home > In Car Electronics > Low fluid level, Bonnet open, Water in Fuel and passenger si
Shippey1974
United Kingdom 2013 Range Rover Sport SDV6 HSE Stornoway Grey
I bought a beautiful 2013 L494 range rover sport late last year and it was running fine, although about 5 weeks ago I passed through a ford (1 foot deep) local to me didn't think anything of it, but the next day I checked the car (oil water etc) for a drive up to Aberdeen approx. 350 mile, as I set off the car went into fault with the above warnings. I pulled over checked levels, shut the bonnet. Checked the indicator but then goes into fault and does not work. Continued my journey and phoned the local RR garage about the Water in fuel he asked "has it been serviced" to which I said "it is just due one now" to which he stated that will cure it" Unfortunately with the COVID-19 the garage is closed.
I have been monitoring this issues since, the car is showing the faults very intermittently, the issues disappear then return without warning.
So my question is has anybody else come across this issue?
If so how did you cure it?
Would a service clear the faults?
Any help will be greatly appreciated
Thanks in advance
Post #598134 Sat Apr 25 2020 4:10pm
