![]() | Home > General > rrs 4.2 s/c |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
Hi, and welcome.
Perforated leather seats were available in the 4.2SC, 2005/06 models. Malaysia Boleh!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
All SC had brembo
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Our 05 supercharged is fully loaded. When I bought it I got lucky I suppose as I knew nothing about them - it just drove nicely. The only thing it doesn't have is a heated steering wheel.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Crikey, I had a 1986 Ford Scorpio 4x4 that had a heated front screen! |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
IIRC.....Ford were the first to fit them off the production line, called them Quickclear windscreens
The heated front screen was a Ford only option as I think they copyrighted it. JLR got to use it under Ford ownership. 2019 5.0 SC SVA (Current)
mjamesm111 Member Since: 18 Apr 2020 Location: devon Posts: 3 ![]() ![]() |
hi guys, i really appreciate the you taking the time to reply👍
All the sunroofs do is leak water so make sure the drains have been unblocked make sure the air con rad is good and the air con works the rear screens are optional in them but what a piece of kit ohh ads about 9-17 mpg |
[quote="Themoog"]Our 05 supercharged is fully loaded. When I bought it I got lucky I suppose as I knew nothing about them - it just drove nicely. The only thing it doesn't have is a heated steering wheel.
There not cheap to run but they are fun and there is loads of help on here and you can source parts/mods quite cheap if you look |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
My feelings exactly! Used the rear DVDs about 2 times, sunroof barely gets used. Brembo's are excellent. I upgraded the standard head unit to a double din one that has Apple CarPlay but that's about it. Fantastic car when it's behaving and I'll find any excuse to get in it even after 3 years. Good luck and enjoy! 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Fire1 Member Since: 19 Mar 2020 Location: Poole Posts: 34 ![]() ![]() ![]() |
Hi all, I too am after a 4.2 SC like the original poster and I too am also confused by specs haha!
So HSE is the landrover main stream top model
