Home > Maintenance & Modifications > EBC Redstuff S/C Front Pads
Never had any problem with the Redstuff pads in 18 months on my S/C, although have now changed to H/D Orangestuff more of a precaution and trial rather than anything else, as had no reply from EBC as to why they dropped the Redstuff ones for the Sport, which really wasn't surprising. Haven't really bedded them in yet so not sure how they will preform, lot of dust initially but not sure if that's more the bedding in coating EBC have on the pads to start with, but have fitted grooved discs as well so probably won't help the dust side of things anyway.
Post #600703 Tue Jun 23 2020 10:14pm
Stevepd
Brit Plumber wrote:
they do chow down on the disc quickly.
What do you mean buy this?. In the next couple of weeks I’m upgrading to the V8 set up. The indie I use said yellow/green stuff were not that great as they were too hard from cold (having to press harder) and advised to go LR pads.
Options were yellow or green on Ferodo coated discs or genuine setup. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #600705 Wed Jun 24 2020 6:33am
Brit Plumber
The discs are wearing down a little quicker than expected but the yellow stuff pads bite from cold, they don’t need time to warm up, it’s instant. I do find that the yellow on the front and red on the back give the car a better feel through the brakes compared to the LR pads, the previous LR pads gave lots of dust and I found a bit susceptible to fade if I was slowing quickly from motorway speeds. If you’re upgrading however you will notice an improvement over standard anyway so you go OEM to start and upgrade in the future. If you have a TDV6/SDV6 then the OEM is likely to be sufficient anyway. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600715 Wed Jun 24 2020 8:21am
