![]() | Home > Maintenance & Modifications > Disco 4.5 / RRS 2 wing mirrors on a 2005 to 09 Sport |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
I would be interested |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
Although i have just replaced my standard ones i would also be interested.....look a bit more modern with the integrated indicator |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
I would be interested too ! |
Ok, I’ll put something together as it’s pretty simple if you can take thing apart and do basic soldering. 2019 5.0 SC SVA (Current)
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hi BritPlumber,
I haven’t as yet, work is getting in the way of lockdown time.
Ok great thanks Brit Plumber, I've found LHD LR4 mirrors with power fold, now to try and find reasonably priced 4.5 mirrors before I can start this 'adventure' 🤣😂
Here’s a start, I’ve listed the wires by plug, first is the 4.5 plug followed by the early RRS plug, I've assumed the 4.5 mirrors have indicators so added that pin on. There is am issue with some wiring which needs you to go into the mirror and do some work. Basically the Disco 3/early RRS has a powerfold module which the Disco 4 dispensed with as it was combined in to the door module. LR then combined one of the movements with the power fold out wire so it performed 2 tasks. This wont work on a disco 3 or early RRS so it requires the soldered joint to be unsoldered. Then a new wire soldering in and connecting to a free space on the disco 4 mirror plug and the existing wire in the disco 3 loom placed into the corresponding door connector.
So pin 3 on the disco 4 mirror plug has 2 functions, power fold out and the Y axis movement. We need to separate those functions out in to 2 wires. if you keep Pin 3 as the Y axis so it matches your disco 3/early RRS loom you just need to separate the powerfold wire (Could be by finding the soldered joint in the mirror loom or just by cutting it where you can get to it and attaching a new wire to the PF motor side of the cut) this wire will now need to run in the mirror loom down to the plug and fitted to a free space and matched to the disco 3 door loom yellow/blue fold out wire.
Cheers Brit Plumber,
They are different, the frame is angled more towards the driver on that side so the problem would be that if you fit RH mirrors to a LHD car, by the time you have the lens at the correct angle, there would be a big open gap on the outside edge. What you could do is look on eBay Uk for cheap basic D4.5 mirrors and then look out for cheap L405 LHD mirrors in the UK and make a good set. JLR obviously dumped a lot of L405 LHD mirrors (USA, Canada and Middle East spec) on the UK market a few years back. I think I still have some that I removed the motor from. I’ll take a look if you’re interested. 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
Guy, I don't know if it will help or not, but when I changed mine a few years back I bought new D4.5 mirrors from L/R although that was to convert a 2010-13 RRS1, unfortunately there a 22 different R/H/D versions listed and equivalent number L/H/D versions not all powerfold etc. etc. mind you probably find the main differences are a couple of extra holes or wires and lots of £'s knowing L/R. |
Good point on the Disco 5 mirrors. The only brackets that fit are Disco 4.5, the frames are the same for 4.5, L405 and L494.
That certainly looks like the right mounting Guy needs Chris, the problem is that is off a SE and that part number does not say it's a powerfold mirror, just a basic mirror with no extras, where as on the numbers I quoted as example's specifically say's fold back which with so many variations make it very hit and miss.
