Home > Technical > How to remove this part so I can change the glow plugs
Darranj7777
Wales 2005 Range Rover Sport TDV6 SE Java Black
Hi all I am trying to change the glow plugs and I am stuck on getting this part out of the way, it looks like a breather box behind the oil filter, it is loose but just not enough to clear the oil filter housing.
Can any one help thanks
Post #597243 Thu Apr 02 2020 10:59am
you need to remove the oil filter.
You then need to squeeze the item to get it past the cam covers.
brute force is required to remove
Be aware glow plugs frequently break on these
Post #597247 Thu Apr 02 2020 11:56am
Darranj7777
Ok thanks oil filter already off, already snapped one of the glow plugs
Post #597248 Thu Apr 02 2020 12:00pm
this is a much less stressful option.
https://www.rrsport.co.uk/forum/topic52753.html
I'd work out how you will resolve it before breaking both sides or difficult to drll rear ones!
Post #597249 Thu Apr 02 2020 12:02pm
Darranj7777
Ok thanks, that would have been a better option before I snapped the glow plug
Post #597250 Thu Apr 02 2020 12:07pm
