Home > General (L494) > Memory seat buttons
louischristie8
2005 Range Rover Sport Supercharged Java Black
Memory seat buttons
Hi,
I’ve got a 2016 SVR and my drivers side memory seat buttons no longer work. When I press the M it doesn’t go orange and the number buttons no longer move the seats.
The lock and unlock buttons still work as does the memory seat buttons on the passenger side.
Anyone else come across this issue?
Are the seat buttons and lock buttons all on one module as such? If the button module has failed would the lock and unlock also fail?
Thanks
Post #596164 Sat Mar 07 2020 2:27pm
JamieLC
I had this on MY16 AB, It sounds a bit silly but what had happened was i had set the my seat position to number one and two so when my wife got in to drive, it wouldn't go to her position because i had accidentally saved my position over hers.
When you press the number then the M (or vice versa cant remember) does it say on the dash - seat position saved? or just no power at all?
Im sure Powerful UK on you tube have done a video on this, not sure if the SVR is the same though.
Post #596275 Mon Mar 09 2020 10:39pm
Eaters
At the risk of teaching to suck eggs, (and this all comes from my ownership of a much older RRS) the M button is for resetting the position of the seats. You set the seat position manually, then push M, then a seat number and it should show "Stored" or "Saved" or whatever. To make them move you only need to push the number buttons.
I'm really sorry if I'm preaching to the converted but, just in case... Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #596291 Tue Mar 10 2020 8:44am
