Home > Faults & Fixes > no suspension at all |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Hi Dulcie. Sorry, can't help you with your specific problem but you would do well to avoid describing it as a Jeep as it will get the experts backs up! Only a minor point I know but... Robin
Wed Feb 26 2020 1:04pm |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 |
Had similar with mine even after a full refurb of the compressor. In the end got new Dunlop (hitachi copy) from MM4x4 for about £330 all in and fitted that.
Wed Feb 26 2020 9:22pm |
dulcie Member Since: 04 Apr 2018 Location: sth yorks Posts: 33 |
thanks matey will be ,getting a new compressor when I check the exhaust wiring and the air tubes just to make sure it is the compressor .I agree that a Dunlop or hitachie might be a sound reliable quality product as the amk I have has only been replaced forty two thousand miles previously and from what I gather in this forum theres two to re calibrate after fitting a different cpmpressor from the original rr one, two meaning amk models and I will match model numbers before buying just to not go through re programming it once fitted it looks as the compressor has been working overtime because there was a load of powder round the pipe in the valve block connection and the pipe was loose.nothing is as simple as just replacing a part on these range rovers but them is absolutely brilliant motors once raite |
Thu Feb 27 2020 7:00pm |
na then dunt thee be getting me into bother me duck it hurt me to call my baby a///////// she,s just as good as me Porsche boxster s 3.2 just a bit stubborn er |
Thu Feb 27 2020 7:11pm |
