Home > Wheels & Tyres > Steel Wheels
HughN
Wales
Steel Wheels
Hi,
If I fit steel wheels to my car what sort of torque should the nuts be tightened to?
Thanks,
Hugh
Post #594916 Sat Feb 15 2020 5:39pm
knwatkins
I would have thought it would be the same as the alloy wheels Hugh (140Nm). Kev
Post #594918 Sat Feb 15 2020 6:18pm
Tyrefitter
120-130nm Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #594919 Sat Feb 15 2020 6:18pm
HughN
Wales
Post #594939 Sat Feb 15 2020 11:21pm
Rusty Ranger
Do you need to use shorter wheel studs? The holes in steel wheels will not be so deep as alloys.
Post #594956 Sun Feb 16 2020 12:51am
Oldandconfused
What steel wheels have you found that's rated to the weight of the RRS? I wasn't aware that steels were ever fitted to them, other than the totally useless space-saver. I seem to remember steel wheels being fitted to the base D2 but they were quite skinny and 16" or 17" which wouldn't go over your brake disks.
Post #594972 Sun Feb 16 2020 9:33am
Tyrefitter
Nuts on RRS not studs Wink Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #594977 Sun Feb 16 2020 10:17am
HughN
Wales
These: https://www.tuffantuk.com/wheels
Post #594985 Sun Feb 16 2020 11:08am
garrycol
Australia
17" wheels will go on a RRS TDV6 (2.7). Either D3 17" if you can find them or BMW X5 rims with different wheel nuts.D2 rims have the wrong offset/centre hub hole for the D3/RRS. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #594995 Sun Feb 16 2020 2:29pm
Oldandconfused
Well you certainly won't have to worry about kerbing your rims with those on. I guess that if they'r rated for a D4 they should be OK on your RRS.
Post #595004 Sun Feb 16 2020 4:32pm
Duc750
ARe these not the same as the Terrafirma ones that have been around for a while ? 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #595012 Sun Feb 16 2020 6:49pm
