![]() | Home > Wheels & Tyres > Grabber AT3 tyre pressure advice |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
I think ATs do look like they're low pressure because of all of the lumps on the sidewall compared to the smooth sidewalls of road tyres.
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Thank you RRSTDV8 - I will adjust to (or possibly just above) 35 and 38 PSI tonight. I was worried about the slight side wall bulge out too. Hope the extra few PSI will sort this. There is no replacement for displacement - W O Bentley
Yep I run 36F 38R (habit - it's what the BMW likes, too) and the fronts do always look a bit 'flat' to me.. slowly getting used to it and not reaching for the compressor every time now! |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
i've always ran with 45 - 48 psi on fronts. 50psi on the rears.
It looks like 38-40 PSI might be a good call. If I never tow, carry heavy luggage, etc is there any reason to run higher pressures in rear tyres anyway (I would have thought more weight in front of an L320 than rear)? Therefore, now thinking of experimenting at 38-40 PSI for both front and rear equally. There is no replacement for displacement - W O Bentley
Wow. Just wow. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Running the rears slightly higher is a way of taming the handling. If the fronts and rears are equal pressures, there's a chance that the vehicle can be tail happy. Even more so if the rears are lower pressure than the fronts. With something that is tall and relatively rolly-polly, you increase the risk of roll-induced oversteer. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
As an experiment tonight I've increased front and rear to 45 PSI and might then lower the fronts slightly if appropriate. There is no replacement for displacement - W O Bentley
45psi is ridiculous, frankly. But hey, they're your tyres and suspension bushes... 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Surely running at those kind off pressures you might as well have solid tyres, or at least buy a neck and back brace. ![]() Cheers Col |
like i said.
horses for courses as you say ![]() 2012 3.0 SDV6 RRS HSE |
What are you towing? I tow a twin axle horse trailer and the tyres are fine at standard factory pressures. How much nose weight are you running? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
periodically towing 12' itwin axle for williams with near enough 3 tons overall.
