Home > General (L494) > Gearbox Clunking & Air Suspension Noise |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
This is likely to be drivetrain play. Have a look at all UJ's and visible areas first.
Thu Feb 13 2020 8:06am |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
The gearbox (and car) have only done about 900 miles - is this normal?
Thu Feb 13 2020 5:09pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 |
Are you lowering it prior to putting the handbrake on or after ? |
Thu Feb 13 2020 7:56pm |
No letting it lower in situ.
Sun Feb 16 2020 1:14pm |
splosh Member Since: 01 May 2019 Location: hampshire Posts: 11 |
I have had Range Rover's since 1972 so I can safely say I have driven a few and experienced their functions.
Sun Feb 16 2020 11:17pm |
Cool I guess I'll turn off the auto EPB - why did they make it a feature if it knackers the car?
Sun Feb 16 2020 11:37pm |
New SVR does the same thing too.
Sun Nov 01 2020 10:19pm |
Noticed the gearbox only makes a thunking change, when you change into gear whilst the car is still over-revving to warm up.
Fri Nov 06 2020 8:46pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Thanks for the info DM...thought it was judt my car.
Fri Nov 06 2020 10:21pm |
I thought it was just mine too.
Sat Nov 07 2020 6:20pm |
Strange thing is this MY20 SDV8 clunks when changing from P to D after you’ve just started the car and the engine doesn’t even have a high-idle setting from the looks of things - minute you start it it just sits at a constant RPM that doesn't go down at all, probably older engine design.
Sun Apr 25 2021 9:11pm |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 40 |
Don't have an RRS currently but having used the same ZF gearbox on my other cars i observed the same thing. BMW updated gearbox etc didn't work but if i followed following mine never made that clunk you described.
Mon Apr 26 2021 8:44am |
Cheers will try that.
Wed Apr 28 2021 6:12pm |
Vaincarp Member Since: 26 May 2021 Location: Antwerp Posts: 1 |
Just wanted to share my experience.
Wed May 26 2021 8:34am |
