Home > Technical > Instrument Cluster
Timo
Instrument Cluster
2009 2.7 Sport
Hi. My instrument cluster keeps switching off whilst driving so i have no speed or anything coming on. I am assuming there must be a fault with it. If i bought a second hand one and replaced it with mine would it work no issues or would the car need connecting up to a computer?
Thanks
Post #594745 Wed Feb 12 2020 2:29pm
geoffsnook
you would need to have it reprogrammed to your car and save all the info from your previous panel there are people on here who have had them repaired on here try searching Thumbs Up
Post #594746 Wed Feb 12 2020 3:34pm
I think it contains the immobiliser code
so if you fit a replacement the car won't start (until its been recoded)
Post #594749 Wed Feb 12 2020 5:16pm
Gerd1986
James1974 on the disco3 forum can do it for you or there is a wealth of knowledge on there to do it yourself.
Post #594750 Wed Feb 12 2020 5:28pm
rob cupples
I had similar symptoms on mine. I sent it away to instrument cluster uk and they repaired it successfully. no reprogramming required this way
Post #594751 Wed Feb 12 2020 6:17pm
Timo
Thanks everyone. I’ll pop over to the disco forum and try speak to james1974
Post #594758 Thu Feb 13 2020 1:35am
aaronjb
Was an early symptom of this bits of illumination flickering? I ask because my 'mph' word flickers from time to time.. and planned repairs are better than 'oh balls none of the clocks work anymore' repairs! Smile 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #594772 Thu Feb 13 2020 10:41am
Timo
It had a slight flicker off then on. Then it would switch off all together for a long period
Post #594775 Thu Feb 13 2020 11:17am
gogsy1956
rev counter needle illumination on mine has flickered for a good while now,,, apparently its a common fault 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #594809 Thu Feb 13 2020 7:17pm
