Home > Wheels & Tyres > Tyres size
JohnBlueSport
United Kingdom 2007 Range Rover Sport TDV6 S Buckingham Blue
Tyres size
Can I fit 255 55r 19 s instead of 255 50r19, without any problems other than speedo being out a bit
Post #594018 Wed Jan 29 2020 8:23pm
Yes. Thumbs Up Been running 255/55/19 for several years on two different RRS.
The speedo won't be out by much and might even be spot on, depending on how much it's out already. 2012 SDV6 - it's missing a couple of cylinders
Post #594021 Wed Jan 29 2020 9:03pm
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi Iā€™m currently on 255/55/19 and the ride is so much better and I imagine much less painful for the cars suspension components (wishbones and bushes etc) I was lucky to buy a second hand set of 19inch wheels that already had this size tyre on and was at first worried if it would be ok to use but went with it and Iā€™m really pleased I did šŸ‘šŸ‘ I still have a set of stormer 20s I intend to refurb and I will put 275/50/20 which fil out the arches perfectly
Post #594685 Tue Feb 11 2020 7:27am
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Will 275 50 20 fit ok with no problems or are alterations to settings required ?, thanks in advance Andy.
Post #594693 Tue Feb 11 2020 11:00am
Alfie
Should be fine as discovery 4s run on this size without issue, I use to run a 45 profile on 20 inch rims so going up by a tad should be ok , ride quality will be way better šŸ‘šŸ‘
Post #594794 Thu Feb 13 2020 4:19pm
andyslandy
Thanks Alfie, as for the original posting I currently run 255/55x19 Goodyear Duratracs and have no problems. The 20" rims that it came on are going back on just deciding whether to go road tyre for good weather months and keep the 19s for winter as they have 10mms across all 4 tyres.
Post #594862 Fri Feb 14 2020 8:02pm
