![]() | Home > Maintenance & Modifications > Removing interior trim on 2012+ RRS |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
Sounds like a job for youtube. |
Try Powerful UK on yoooo tooooobe Visitor from fullfatrr.com
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
If you download this file/workshop manual it will have what you need in Section 5 Body Section.
The centre trim removal involves the removal of the top console which quite straight forward. The door card I found needed fingers of steel because using tools can damage the leather, I have plastic trim tools but even those require careful use. 2019 5.0 SC SVA (Current)
