Home > Australia & New Zealand > Going Rate for Brake Pad replacement |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
being quoted about $940 for both axles includes them doing something with the discs which is normal apparently. Anyone been stung by a local dealer for this ?? Interested to know what others have paid down under
Mon Feb 26 2007 9:52am |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
Sheeeeeeyit! Mind you I did pay a fair bit for the BMW 323i brakes + rotors. How many Km's do you have on yours Jim? RRS TDV6 Bluetooth, VR, Roof
Wed Feb 28 2007 11:20am |
TonyMeg Member Since: 10 Feb 2007 Location: North East Posts: 128 |
On my first service Zilch i was charged an extra £150 for front pads & new wiper blades including fitting if that helps any They shouldn't need to skim the disc's unless you've went metal to metal with them & badly scored them? |
Wed Feb 28 2007 11:24am |
They do a lot of replacing of rotors these days. I know BMW told me that the rotors are softer to give better braking characteristics so they wear with the pads. Maybe just BMW, but sounds credible. Check how badly the rotors are worn Jim. RRS TDV6 Bluetooth, VR, Roof |
Wed Feb 28 2007 11:34am |
thats what they must be doing, they stated about 3 month/3000 k's left on the pads, so not at the level to panic. I am going to find out if one of the British/Swedish specialists can do it, with of course the correct parts so as not to invalidate warranty. Thing as only done 18000K's or 11K Miles for my countrymen .. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Fri Mar 02 2007 6:41am |
been away to ole blighty, and let the wife drop the car in to have the brake pads checked and changed by the stealer..whilst i was away. quite pleasantly surprised that they charged 250 dollars per axle, 500 of her majesties Australian dollar to replace front and rear pads, not the original 940 quoted Another Pommie Bar Steward down under
Fri May 18 2007 7:47am |
