Home > Technical > What's this connector
Lindab
While fitting a permanent feed connector in the boot, I came across this connector down by the side of the battery tray. Can anyone tell me what its for. L494, car was bought new by me so its not someone else's addition which was then disconnected Confused
Post #593419 Fri Jan 17 2020 2:23pm
Martin
Site Administrator & Owner
Transit relay connector, not used once the car has gone through the PDI Smile Like this site? Buy some RRSPORT goodies to show your support!
Post #593427 Fri Jan 17 2020 4:12pm
Lindab
Thanks for that Very Happy Was hoping it would give me another 50mpg when connected Sad Thumbs Up
Post #593439 Fri Jan 17 2020 6:33pm
Eaters
Now that would be good! Rolling with laughter Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #593475 Sat Jan 18 2020 1:46pm
Camelrock
No that connecter is called the AA saves on mileage as well 👍😉 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #593483 Sat Jan 18 2020 5:15pm
pjbracer1
out of interest what happens if its connected back up? If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #607756 Tue Dec 22 2020 11:34am
The item it is connects to before delivery isn't present.
Post #607758 Tue Dec 22 2020 12:09pm
pjbracer1
so once its been disconnected the connection is broken and cant be re-used If a jobs worth doing, get a someone who knows what they are doing to do it!
RR P38 HSE V8
Post #607759 Tue Dec 22 2020 1:35pm
As it's used to limit some of the electrical functions during delivery/storage to conserve battery power not sure what else it could be used for if any, as the relay is physically removed by the dealer prior to delivering the vehicle to the customer, not sure you could even obtain a replacement relay if you wanted to store your vehicle for a period of time.
Post #607772 Tue Dec 22 2020 7:29pm
pjbracer1
Yeah makes sense I guess, just wondered more than anything else really I gues it just shut donw all the things that drain the battery that wouldnt be needed like alarm etc...
Just thought it could have been a option for some of the guys around the world who mothball the car over winter or if we have another lockdown! If a jobs worth doing, get a someone who knows what they are doing to do it!
RR P38 HSE V8
Post #607798 Wed Dec 23 2020 10:39am
As with many things JLR, there are several (incompatible) variants of transit relay.
They fit on a battery terminal. (initially the earth terminal I think, but now on the positive terminal)
What they do (on the older models) is completely isolate the battery until the ignition is turned on.
Therefore your remote locking does not work or clock etc.
So while they are good for when parked up for winter, you wouldn't want it fitted all year round.
Post #607805 Wed Dec 23 2020 12:02pm
Easiest solution, just buy a Ctek smart charger assuming you have a power supply where vehicle stored.
Post #607825 Wed Dec 23 2020 7:48pm
