Home > Faults & Fixes > Central Locking Tempremantal / Not Working
Irving
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
I just got a 2012 RRS Autobiography.
I have noticed that the passenger door doesn't unlock when using the key to unlock all the doors (Yes, global unlock is turned on). All the other doors open (most of the time).
HOwever, if I have the key on me and go to open the passenger door it does unlock fine, just not when using the unlock button on the key.
I thought yesterday that the issue was just on the passenger door but earlier the driver door had the same issue where it would not unlock unless i had the key near the door (keyless entry). That only happened once, and also at another point all the doors were unlocked but the rear driver door wouldn't unlock no matter if i had the key or not.
So there seems to be some gremlins in there, but I cant understand why it would work for keyless entry but not on the button pushes on the key fob.
Post #593377 Thu Jan 16 2020 2:42pm
