![]() | Home > General (L494) > Dashboard and Infotainment screen brightness keeps varying |
splosh Member Since: 01 May 2019 Location: hampshire Posts: 11 ![]() ![]() ![]() |
2017 MY 4.4 Autobigraphy 24k miles.
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
mine started doing this the other day, strangely only when in apple car play mode |
I heard about Stealth Mode but couldn't find it on the screen.
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
I'm sorry to tell you but over multiple LR products they all have a properly wonky light sensor and work as you described.
Agree,
ghunkin Member Since: 18 Feb 2018 Location: Nottingham Posts: 36 ![]() ![]() |
I had to take my P400E in to Stratstones twice before they found the issue - a faulty control unit. This was replaced and all is fine now. |
It's good to get this feedback as the car has just finnished warranty should the fault re-occur.
mrsammyp Member Since: 04 Nov 2019 Location: Kent Posts: 56 ![]() ![]() |
Does anybody’s dash screen / speed dial screen look like it’s bleeding light on the bottom half of the screen? I’m not sure whether this is normal or the screen should be the same colours all over. It’s under warranty anyway. |
NO.
Thanks for the suggestion.
