![]() | Home > General > On the hunt for L320 |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
If you search for Buying Guide, you'll find a lot of info here (such as https://www.rrsport.co.uk/forum/topic46842...rs+guide).
B_Tank88 Member Since: 27 Dec 2019 Location: Earl Shilton, Leicester Posts: 12 ![]() ![]() |
Thanks, I read through that PDF guide.
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 222 ![]() ![]() ![]() |
I bought privately , the advice I was given was to ensure a full service history was available to scrutinese thoroughly which it was, low ownership is also a plus mine had 2 previous owners & by a colleague at work who has one to definitely avoid the 2.7 had mine almost 4 months & it is the most comfortable vehicle I've ever driven it's 2007 3.6 TDV8 & now has 90,000 miles showing the previous owner had the engine oil changed every six months as he was told that this helps the turbochargers I will keep this maintenance up as they are a costly repair if they fail, the only item I have replaced is a central locking door actuator this is a common fault & my independent changed it in about 1 hour, good luck with your search. |
Tom_w_27 Member Since: 09 Sep 2018 Location: Norfolk Posts: 40 ![]() ![]() ![]() |
I would agree buy a low mileage, low owner cherished car.
