Home > In Car Electronics > Thinkware U1000 Dash Cam
Just updated my Thinkware F770 Dash Cam to the new U1000, no particular reason just thought it was time for a change as the F770 must be well over 3 years old now. Was it worth it, No not really cosmetically it looks a little nicer rather than a rectangle box, better image from camera being 4K but that's about it, otherwise does just about the same as the F770 except twice the price. There is a additional motion detecting radar unit you can buy extra for it, which is basically a energy saving device when in Parking Mode which wakes the camera up if motion detected, only trouble is it only works if motion is detected at front of vehicle not the rear. Going to try a 250GB card in it to see if it works but is listed as only taking up to 128GB. One bonus is it uses the same hardwire power feed and cable for rear camera so no rewiring. Generally nice camera but to expensive to recommend buying one at the moment, maybe when price drops, but have to admit the F770 is a very good camera apart from looking a bit dated will take some beating. Forgot to mention due to the high resolution or whatever of the camera the PC viewer can't show both front and rear images at the same time on the screen.
Post #592252 Mon Dec 23 2019 8:47am
Tyrefitter
Look a good bit of kit Col but like you say a bit pricey,does it also have the feature where you can press the manual record button like on the 770 as I think that comes in handy sometimes. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #592257 Mon Dec 23 2019 9:52am
Yeah, the silver button show in the picture is the manual record button.
Post #592259 Mon Dec 23 2019 9:55am
Tyrefitter
Looks more visible than the one on the 770 Thumbs Up Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #592260 Mon Dec 23 2019 9:57am
That one's o.k. the others wifi, power etc are bit difficult to see same as the F770 though, would have been better if they were a slighty different colour but not a major issue.
Post #592262 Mon Dec 23 2019 10:08am
Eaters
I've commented before about this slight niggle with the F770. I would have thought it wouldn't have been too difficult to provide them with gentle LED back illumination when the engine is running. Interesting to hear that you still rate the F770. Guess I'll save my pennies for now. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #592272 Mon Dec 23 2019 12:51pm
Yeah, personally still rate the F770 as one of the best and it will take some beating, a few extra features on the U1000 that probably never use anyway, bit like a lot of things these days just gimmicks that are not really needed. Meant to say they appear to have improved the GPS connectivity on the U1000 as it only takes a few seconds to connect now has even done it with car parked in the garage on a couple of occasions.
Post #592304 Mon Dec 23 2019 8:50pm
Should it be of any interest to anybody have tried one of these Sandisk 256gb cards in camera and works fine although spec. says max. 128gb.
Won't work in a F770 though. Laughing
Post #592522 Mon Dec 30 2019 3:15am
SRE
Spain
Nice feedback, guess I will stay with the 770. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #592523 Mon Dec 30 2019 8:37am
256gb card just stopped working so may not be compatible after all, been alright for a few days, I think it may have been after I tried it in the F770 as a experiment can't really see that would have done anything to the card though, re-formatted it but still not working will get another 256gb and try it, if that doesn't work not a real problem will just have to stick with 128gb one's.
Post #592620 Thu Jan 02 2020 2:21am
May be of use to someone, but just had another play with 256gb instead of the maximum 128gb card Thinkware say it will accept, a new 256gb card works fine, however if you re-format the 256 card using the camera app via a smartphone or PC viewer (The camera it's self no longer has the Format button on it unlike the F770) it does something to the card and it will no longer work for whatever reason even if you do a full re-format on a PC. If however you only ever re-format the card using a Windows PC it will work fine. Don't really know why this should be the case but that's what seems to happen, just thought it might save somebody wasting a card, although the card still works just not in the camera. I suppose the obvious solution is buy a couple of 128gb card and just swap them over. Laughing
Post #593750 Fri Jan 24 2020 8:50am
Eaters
Very interesting Col. I wonder if Thinkware are aware. Robin
Gone:
MGZTT 190 2.5
Post #593751 Fri Jan 24 2020 8:52am
Robin, I'm inclined to think if anyone actualy mentioned it to Thinkware they would just say but it's only supposed to accept a maximum 128gb card.
Co
Post #593753 Fri Jan 24 2020 9:02am
Eaters
Rolling with laughter Robin
Gone:
MGZTT 190 2.5
Post #593761 Fri Jan 24 2020 10:36am
Tyrefitter
Col I’m about to hardwire my 770 into my RS,can you remind me which of the 2 wires red & yellow is the permanent live & which is switched live.? Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #602467 Thu Jul 30 2020 3:18am
