Home > Technical > Headlight fuse!
Ian Grant
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Headlight fuse!
I have a 2007 RR Sport 3.6 hse and have replaced the drivers side headlight bulb thinking it had gone (xenon). It still doesn’t work so I thought that I would check the fuse but cannot find which one it is. I have a manual but it doesn’t seem to list it or at least not in a way I can identify it.
Hopefully someone will know!
Thanks guys.
Ian Thumbs Up
Post #592180 Sat Dec 21 2019 5:25pm
There isn’t a fuse.
It could be the balast silver box under the headlight.
Try removing both headlight assemblies
Take the non working headlight and plug it in the other side and see if it works
Post #592183 Sat Dec 21 2019 7:06pm
Ian Grant
Thanks for replying and excuse my ignorance. I will try eliminating things as you suggest so thanks very much for your help.
Ian
Post #592216 Sun Dec 22 2019 1:40pm
