Home > General (L494) > All Season tyres
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
All Season tyres
am thinking of buying these instead of the contis ive got on now anyone got these on theres what do you think about them are they better Thumbs Up
Pirelli Scorpion Verde ALL Season
275/45 R21 110W XL, M+S, Land Rover, NCS
Post #591974 Tue Dec 17 2019 5:52pm
Renaco
Those all seasons are taking much longer braking distance than proper summer or for the season now the winter tires.
I would never again use all seasons on such a heavy car... 2012 RRS HSE SDV6, BOURNVILLE 12/12-10/14
2015 RRS DYNAMIC HYBRID, CAUSEWAY GREY 1/15-7/18
2018 RRS DYNAMIC P400e, BRITISH RACING GREEN 8/18-8/19
2019 RRS DYNAMIC P525, SILICON SILVER 8/19-8/22
2020 RR VOGUE D300, EIGER GREY 9/22-7/24
2025 RR P550e, CHARENTE GREY 8/24-
Post #591977 Tue Dec 17 2019 6:20pm
syl
This is an interesting test. In the dry, summer tyres are best even in the cold. In wet winter weather, all season tyres are probably best. On snow/ice, , well, that's been done before and should be fairly obvious (though the difference is not huge between winter and all-season).
In the southern UK, where we get snow one or two days a year occasionally and most days it's way above freezing, I'm sticking with all-seasons on all my cars that are used year round.
The Pirelli's aren't the best all-season for grip though, but I believe the wear rate is good. I think it's more dry biased and doesn't have the mountain/snowflake marker.
http://www.tyrereviews.co.uk/Article/2019-...e-Test.htm
 RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #591980 Tue Dec 17 2019 7:54pm
riverblanche
Hi,
Totally agree with Syl ^
I would be looking at AT3's or crossclimates I have run true Winters but think for most of the time All seasons would be best
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #591984 Tue Dec 17 2019 9:48pm
Renaco
If it’s cold outside without snow or ice, just wet or dry, even then all-seasons are less good in grip than proper winters...
It’s all about the rubber/silica mix for cold conditions, it is impossible to get a rubber working perfect in +40 and same time -10.
Does anybody wear the same outerwear or shoes in the cold as in the warm climate? If this would work, it where fantastic.
But the myth of a 4x4 fine on all seasons below 5 degrees will never die... 😉 2012 RRS HSE SDV6, BOURNVILLE 12/12-10/14
Post #591991 Wed Dec 18 2019 6:36am
Tyrefitter
If I was to keep with the sport long term I would probably opt for a set of 22" rims with summer tyres & then go for 21" with winters & just change them as & when. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #591996 Wed Dec 18 2019 8:03am
The move to "winter-rated summer tyres" such as the Michelin CrossClimate is likely to work well in countries like the UK where, most of the time, it's cold and wet in winter rather than icy and snowy. Sure, Scotland and some upland areas elsewhere in the UK get decent ice and snow, but for most of the population a full winter tyre is probably overkill.
If people would fit something like the CrossClimate all year round, we could get away from the silly situations we see where the motorways are gridlocked. Away from scenes on the news of people unable to drive up the slightest incline on urban roads.
You'll never get wholesale adoption of winter tyres in the UK - the drivers of all those cars on PCP deals, for example, won't be forking out for extra wheels/tyres for cars they can barely afford the payments on in the first place. But if tyres were fitted, as standard, that matched the CrossClimate's proven abilities, the country would be better off in winter.
All of the above is not applicable to countries / areas that have "proper" winter conditions for significant periods of time, of course. They need winter tyres. 2012 SDV6 - it's missing a couple of cylinders
Post #592001 Wed Dec 18 2019 8:55am
dazzerboy
Which tyres do people recommend then ?
Post #592020 Wed Dec 18 2019 5:15pm
riverblanche
There are a few trials that say the opposite, with All season tyres braking shorter than Winters on wet and dry cold roads, its when there is snow and ice that the Winters come more into their own.
Bit like life, everything is a compromise depends what your priorities are Thumbs Up Porsche Cayenne 2022
Post #592023 Wed Dec 18 2019 6:27pm
I was going to say the CorssClimate SUV but then I remembered you're on 21 inch rims and they only go up to 20.
I'd probably go for the Pirelli Verde all season as in your original post. Not much choice in that size so far as a quick google goes. It's the tyre that LR fit to their range in many cases so probably works well with the on board systems too. 2012 SDV6 - it's missing a couple of cylinders
Post #592024 Wed Dec 18 2019 6:30pm
riverblanche
And
there about Whistle £192 each fitted or so I have just found out Sad Porsche Cayenne 2022
Post #592025 Wed Dec 18 2019 6:36pm
syl
Did you watch the video?
Summer tyres (never mind all-season tyres) stopped quicker in dry conditions than winter tyres even down to 0 degrees.
All-season tyres stopped quicker than winter tyres in wet conditions down to 2 degrees.
Winter tyres were better in the snow. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #592046 Wed Dec 18 2019 11:12pm
riverblanche wrote:
And
Decent tyres are worth the extra over Chinese ditch finders... Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #592061 Thu Dec 19 2019 9:31am
jonathana13
I run Conti Sport contacts in the summer and Pirelli scorpion winters for the winter. If I was going to run an all season it would be the Pirelli Scorpion Verde, but That’s just personal preference as I found they had a more direct turn in. Out of interest where are you based? I have a set of almost new cross contacts which I think are in the right size and would be keen to get rid of them at a discounted price.
Post #592152 Sat Dec 21 2019 9:38am
timhum
My present car came on Pirelli Scorpion Verde tyres rather the the Michelin of the previous car. I mucgh prefer the feel of the Pirellis. For winter I use the Scorpion Winter tyres as we visit the area around Geneva quite frequently and winters are mandatory in the area. The big drawback of the winter tyres is in my opinion the big negative effect on fuel consumption, I reckon they lose me 3mpg. Do others share the same observation? Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #592174 Sat Dec 21 2019 2:26pm
