Home > Technical > Lower Front Arms
Lower Front Arms
Just replaced lower front suspension arms fitted with poly bushes, however finding the ride a little to harsh for my likening so going to do it all again with new arms fitted the Meyle solid bushes and see how we get on with those, at least bolts will come out easy this time Rolling with laughter to be fair though only had to cut one bolt to remove original arm so not to bad.
Post #591946 Tue Dec 17 2019 7:31am
knwatkins
Good luck Col Thumbs Up You are definitely making the right choice.
I've heard bad things about polybushed lower front arms. In fact I recently saw a post somewhere concerning either a Disco 4 or a RRS where the front lower arm had actually snapped because of the polybush's inability to flex. Shocked For this reason alone, I'd always stick with rubber. Kev
Post #591948 Tue Dec 17 2019 8:47am
Disco_Mikey
If you insist on Polys, fit Superpro Thumbs Up
More expensive than Polybush etc, but a much better design of bushing Thumbs Up
Otherwise, Meyle HD arms Thumbs Up
Post #591981 Tue Dec 17 2019 8:35pm
Thanks Mikey, Thumbs Up not sure what make of bush the poly one's are they were fitted to complete arms from A/F, have now ordered a set with the Meyle bushes fitted from them. As have a spare set of arms may well fit Superpro bushes to them as spares or sell them on, just one genuine L/R Hydra bush down here alone is £125.00 as based on mileage I do these days probably never need them.
Post #591982 Tue Dec 17 2019 8:58pm
Stevepd
I found this the other day
 2006 2.7 TDV6 HSE in Cairns Blue.
Post #592017 Wed Dec 18 2019 4:29pm
Just swapped the front lower arms again with one's fitted with Meyle HD bushes and have to say found them a much smoother ride than the poly bush ones I previously fitted which were a little to harsh for me, so personally have to say I prefer the rubber bushes. Now just got to find someone down here who knows how to do the alignment correctly, not to many seem to have the Hunter equipment either.
Post #593280 Tue Jan 14 2020 9:39am
Disco_Mikey
Thanks for posting that, it was highly informative Bow down
Post #593288 Tue Jan 14 2020 12:54pm
mrluke
Re: Lower Front Arms
Col did you only replace the lower front arms? Or did you do the whole lot.
Do Meyle do rear arms also ? Mine is a 2012 RRS
Post #597356 Sat Apr 04 2020 3:29pm
knwatkins
I have the Meyle Heavy Duty front lower arms from AF on mine.
I believe the HD variants are only available for the front lowers.
Standard duty are available for the other arms (I think).
Be careful with the standard Meyle components. I remember looking around on the web previously and whilst their HD kit is well thought of, many people have had issues with their SD stuff for other marques. Kev
Post #597367 Sat Apr 04 2020 8:09pm
Yeah, only replaced the front arms with the Meyle H/D bushes fitted as they were the only one's needed, certainly seem good quality and fair price, personal preference but wouldn't recommend the polybush ones as bit to harsh for me. Like Kevin said I don't think A/F list the other arms/bushes as H/D.
Ceers
Post #597379 Sun Apr 05 2020 8:51am
