Home > General (L494) > P400e Loan Car Thoughts |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 |
If you want to load around 20% while driving, switch to sand mode and deactivate HDC.
Tue Dec 17 2019 4:49am |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
Ah cool! Didn't know that.
Tue Dec 17 2019 3:21pm |
I didn’t know that Auto hold brake is available for the RRS.
Tue Dec 17 2019 6:39pm |
Ratkat Member Since: 02 Oct 2017 Location: Wolverhampton Posts: 57 |
Could be the seatbelt sensor playing up, according to the manual it is a safety feature:
Wed Dec 18 2019 7:31am |
Surprising that there is so little energy regen from driving with e P400e - on a 60 mile motorway run From home to Edinburgh I can add 18 miles charge (that’s nearly a fully HV battery load) to the battery in the Countryman PHEV just recovering wasted engine energy on down hill stretches and through light braking. If I use S mode for gear changes the regen is even more effective but I’ve only ever tried Spirt mode once and it’s unnecessary in a car that will do 0-60 in 6 seconds in D anyway 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Dec 18 2019 12:49pm |
Cunny678 Member Since: 08 Feb 2019 Location: Manchester Posts: 56 |
I have had mine three months now and the average over 3000 miles is 47 MPG. I can get about 15 miles all electric range which covers most of my drives at the weekend. During my weekday commute its 34 miles round trip, mainly slowish mortorway, with no charging at the office and I probably average about 50mpg.
Wed Dec 18 2019 1:40pm |
Yes I've fixed the sensor issue with a bit of yanking and tugging so I remove my comments about the EPB and weird brakes now they just feel like normal regenerative brakes which is fine.
Wed Dec 18 2019 6:37pm |
sbradleyrr Member Since: 13 Jul 2018 Location: Cheshire Posts: 13 |
when the battery is depleted whilst running it in normal (Parallel) mode, how much is the performance affected? |
Thu Dec 19 2019 5:09pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Generally, the battery is never depleted, so performance is always there, as is EV pull away. 0% doesn’t mean 0%.
Thu Dec 19 2019 9:43pm |
Harry is Brilliant. his channel is what the Broadcast car shows should be. His farming channel is also brilliant even for those of us with no interest whatsoever in farming, his way of broadcasting the information is addictive.
Fri Dec 20 2019 2:41am |
Yep good video of the car.
Fri Dec 20 2019 11:46pm |
Also if you're not charging much it and not being feather light with the throttle, you're getting high teens in Central London MPG wise - ironically roughly what you'd get when you didn't charge an XC60 T8 or XC90 T8 !!
Tue Dec 24 2019 1:12am |
Just got back from Bond Street... SAVE mode, stop start disabled for first 15 mins or so, got this:
Thu Dec 26 2019 3:08pm |
