![]() | Home > Technical > RRS 2.7 V6, fire! |
Ukhozi Member Since: 29 Nov 2019 Location: Estepona Posts: 7 ![]() ![]() ![]() |
Hallo, anyone at home?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
not heard that before.
Nope, still waiting for the blue connector to arrive and for some kind soul to look and tell me the pin-out of it. I know there are a pair of twisted yellow/yellow black to the ECU, a thick red, a thick blue but the rest I will need to undo the loom but still don't know what pins a they burnt off. I am assured the s/h unit was not subject to trauma so will probably not need re-programing. |
connector C1854R NOT SURE IF THIS IS THE BLUE CONNECTOR
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Is the connector you ordered YPC114160 ?
Many, many thanks guys.
If you can get a copy of the RRS or Disco 4 wiring manual with connector diagrams, it lists the pigtail kits to use in the connector blocks. I’ve not had a single plug from LR that came with pins or pigtails. I’ve always had to get the pins from mouser or the pigtails from Ford Motor craft or LR. 2019 5.0 SC SVA (Current)
