Home > Technical > Supercharged 5.0 V8 fault
ShooterNeil
Restricted performance with fault code
P0019
What’s this going to cost new chains ?
 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #591674 Mon Dec 09 2019 7:29pm
Hamtheman
South Africa 2011 Range Rover Sport Supercharged Alaska White
I had the same , along with a rattling chain, in my case it was indeed new chain as well as 32 new valves and a head overhaul.....sorry.
It may be a faulty cam position sensor, but that is me just being optimistic
Post #591706 Tue Dec 10 2019 8:10am
Brit Plumber
I’d also expect new chains and tensioners. Mine had a new engine in 2013 so I hope it got the revised kit installed. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #591748 Wed Dec 11 2019 8:38am
came across these today:
Post #591766 Wed Dec 11 2019 4:25pm
ShooterNeil
After trying to get quotes for the work and was told it’s to big a job
A local bmw Mercedes specialist have agreed to do the work as have half the kit needed to lock the engine
Others have said the locking kits/tools are to expensive and not worth buying
Some even said They have never heard of that happening on the that model and age on the older 4.2/4.4 but not the 5.0
So I got a fiesta for 400£ To run about in till they can do the work mid/end of February
Will update when I have more info
20 hours labour is the time quoted to do the work
Neil 61 AB 5.0 supercharged rocket
Post #591823 Thu Dec 12 2019 11:01pm
ShooterNeil
And look what the lads did at work
Post #591847 Fri Dec 13 2019 10:27pm
Tyrefitter
^ Laughing Laughing Laughing Laughing Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #591853 Sat Dec 14 2019 9:01am
Not a bad Ideal for me.
My other cars a RR but it’s at the garage.
Or I can’t rely on it. Laughing
Post #591857 Sat Dec 14 2019 11:41am
ShooterNeil
So tomorrow morning my supercharged sport is getting a ride to the garage to hopefully be fixed by the end of the week 61 AB 5.0 supercharged rocket
Post #595452 Sun Feb 23 2020 4:13pm
ShooterNeil
Still not fixed or moved from the day it got dropped off
so moving it to another garage that’s done this job more than once
Will this ever end 61 AB 5.0 supercharged rocket
Post #597570 Thu Apr 09 2020 1:04pm
ShooterNeil
Update
Having new water pump and one injector was stuck in so waiting now for the bits hopefully Monday or Tuesday pick it up Very Happy Very Happy Very Happy Very Happy Buckingham Blue 61 AB 5.0 supercharged rocket
Post #598056 Thu Apr 23 2020 2:14pm
ShooterNeil
Just picked my car up it first went off the road on 9th December 2019
So it’s had new chains guides tensioners water pump fuel injector as it was corroded in oil and filter change
It was not easy to get the right garage to do the work but got there in the end
Cost just under 2k 61 AB 5.0 supercharged rocket
Post #598257 Tue Apr 28 2020 3:27pm
kansanbrit
United States 2011 Range Rover Sport Supercharged Zambezi Silver
Are you sure that included new chains? That is usually a body off job. Tensioners and guides only are much easier. I know, I am currently doing it.
Post #598371 Fri May 01 2020 2:06am
ShooterNeil
Yes and no need to remove the body only if the heads have to come off 61 AB 5.0 supercharged rocket
Post #598397 Fri May 01 2020 2:40pm
ilard
I am waiting for the punchline to this thread:
Quote:
and after all these weeks I realised that 1.1 litres is more than enough for me so the Fiesta is staying. See the Wanted section if you're interested in a 5.0 SC
Rolling with laughter
Or before you know it you'll have crossed over to the REAL dark side and be rolling around in a 2.0 litre four pot 2.5 tonne Range Rover Shocked L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #598409 Fri May 01 2020 8:30pm
