![]() | Home > Technical > L320 2.7 V6 going nuts. flashing, clicking, not starting. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I'm definitely not an expert but is it worth trying the simple stuff first - the brake light switch has been known to cause all sorts of problems but is a simple and relatively cheap replacement. And rear brake light bulbs as well... Robin
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
As above...sounds mad but definately replace the brake light switch.... it’s poor quality and occasionally arcs across the contacts sending spurious messages back to the BCM.... this then throws a wobbly as it can’t compute the readings and throws everything into limp home mode...
quadrant Member Since: 28 Oct 2019 Location: Sheffield Posts: 6 ![]() ![]() |
Have you checked the alternator voltage?, I had exactly the same symptoms as this around two weeks ago whilst driving on the M1 Motorway, doors started locking and unlocking and all the lights were going mad on the dash, gearbox went into fault and suspension self lowered.
Ukhozi Member Since: 29 Nov 2019 Location: Estepona Posts: 7 ![]() ![]() ![]() |
After all the wild guesses, thanks, it was a burnt out integrated transfer case. very close to setting the whole car alight, stupid place to put delicate electrics, under the scuttle, what were they thinking.
Well done and good to know |
