![]() | Home > Technical > L320 2.7 TDV6 parking brake. Terrible grinding noise |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
Normally problems with the EPB are associated with a screeching noise,, but in any case have the system cleaned and adjusted correctly and with a bit of luck it may be ok 2010 RRS, TDV8
holland389 Member Since: 21 May 2019 Location: Mayenne Posts: 15 ![]() ![]() |
So I thought I'd update this post. I ended up removing the EPB and installing new cables. I also ended up removing both hub knuckles and installing new back plates, wheel bearings and bushes top and bottom (bought a 12 tons press). I also removed the EPB mounting plate and refurbished it with new mountings for the EPB box which also needed new fixing screws on the lid. I bought gears for the EPB but didn't use them. I replaced all the shoes, springs and pins.
That's good news.
I think it is because I took a lot of time.....weeks. every time I removed something there was something else that needed removing. I had to pluck up courage for each task. But also the car is the daily drive so it had to be useable after each fix. Maybe I'll tell everyone how I fixed my jammed VVT turbo mechanism with the body still on. |
