![]() | Home > Technical > 2006 RR Sport temp gauge issue. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
There is an oil temp sensor which does effect the gauge
jfleet84 Member Since: 21 Dec 2016 Location: crewe Posts: 14 ![]() ![]() |
I’ll give that a go if it works. As when the temp falls to zero it’s as if the car thinks it’s stone cold and revs a little higher at idle to warm it up. I didn’t realise that the oil temp sensor could have an effect on the water temp. These cars are always a learning curve |
1 in the sump |
