Home > Technical > Wierd Rear door locking problem.
DanLewell
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi,
This is my first post, so be gentle...
I've had a quick look around and seen lots of other problems with rear doors and unlocking but cant find my particular problem anywhere so thought I would pick your brains.
I've just got a 2013 RRS autobiography with keyless entry. My rear passenger side door will open if I open that door first, and it then unlocks all the other doors. But if I open any other door first, then that door stays locked.
The lock on the door doesn't open if I press the unlock button on the drivers door either, but if someone sitting in the rear moves the lock to open manually then they can open the door.
Is this a setting to change (whihc I can probably manage) or a part to replace (which I will probably manage despite telling myself that Im going to do more harm than good whilst I do it.)?
Cheers,
Dan.
Post #590557 Mon Nov 18 2019 1:50pm
Tyrefitter
Hi & welcome to the forum Dan,first of all have you got the RRS1 or RRS2 as my13 was the changeover year from old shape to new. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #590558 Mon Nov 18 2019 3:19pm
DanLewell
Hi.
Its RRS1, couldnt afford RRS2, maybe in a couple of years.
Cheers,
Dan.
Post #590559 Mon Nov 18 2019 3:30pm
scarey
do a battery reset, maybe a reboot will help..
Post #590561 Mon Nov 18 2019 4:24pm
Had a very similar issue on my MY13 recently with O/S rear door, new lock/catch sorted it.
Post #590584 Mon Nov 18 2019 9:45pm
aaronjb
Likewise - the first couple of times, the rear passenger could unlock it from the inside.. then that stopped working, too, and they had to climb over to the other side to get out Whistle New lock motor assembly fixed it. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590602 Tue Nov 19 2019 9:41am
Boxers
Both rear actuators have been replaced on mine since I purchased it in September previous owner did one just before I collected it and I had the opposite side replaced about a month after I bought it, appears to be a very common failure.
Post #590604 Tue Nov 19 2019 10:22am
