Home > Technical > Supercharged turns over no start
ofremstad
Norway 2005 Range Rover Sport Supercharged Java Black
Problem finaly solved. The engine did not come up with any fault codes so manual fault seeking had to be performed.
The Ingition coil sensor was burnt. Part number: 4H23-18801-AA.
Happy days
Hi All. Very Happy
Greetings from Norway and my first post.
We took the 2005 Supercharged for a drive today, and all went fine until we stoppet the car for a visit.
When we try to start the startmotor goes inn as normal but no ignition what so ever. and the startmotor runs even if we let go of start key.... if we take key to zero position it stops. we have chekked all fuses etc.. and tried startgas. and the diagnose tool (not IID tool) do not come up with any faults.. it just cranks.. and countinue to do so upto 30 sek.
HEEELP
Post #590527 Sun Nov 17 2019 6:45pm
1richard1
Have you got fuel?
Post #590528 Sun Nov 17 2019 7:04pm
Brit Plumber
Is the engine actually turning over or just the starter turning? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590541 Mon Nov 18 2019 7:37am
