Home > General (L494) > Service indication
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Service indication
I'm getting a service required in 1800 miles indication on startup. Car was new 2017 September and now has 41412 miles on the clock. the warning has also appeared on the 'In Control' app.
So what's the problem I hear you say. Well it said exactly the same thing last month so I booked it into the dealership for a service. two days later the indication dissipated from both indicators. I waited a couple of days but it did not return. So went into the dealership to consult and was informed that from the maintenance records I was not due a service yet and there had been some problems with the 'in control' app. Hence cancelled the service.
The indication reappeared yesterday and ever since.
Long winded story so apologies.
My question is has anyone had a similar spurious indications?
I'm suspicious because since the first indication I have covered at least 500 mines but the has remained 1800.
Advice gratefully received.
Post #590433 Fri Nov 15 2019 11:21am
Lindab
Its 12months or 12000miles (may be wrong on the mileage)whatever comes first. My car has only done around 2500 miles since the last service. Its 12 month anniversary is 25 Nov & its booked in for then. My 1800 mile indicator came up about a month ago. The car has done about 100miles since then, but its now reading "service due" with the spanner sign so the 1800 miles meant nothing to mine as its the 12month timeframe.. If your doing big miles it probably flags up when close to reaching 12000 miles
Post #590438 Fri Nov 15 2019 12:03pm
Hugh Haddow
Thanks Lindab. I thought it was 16000 miles. I do quite high mileage, typically 20k per year. This is my fourth RRS but never seen this before.
I’ll book it back in with the dealership.
Hugh
Post #590446 Fri Nov 15 2019 1:01pm
Tyrefitter
12 month or 16000 miles with the sport.Just reset the servic3 light yourself & it will also go off on the app,well mine did. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #590453 Fri Nov 15 2019 2:39pm
riverblanche
Hi,
How long time and mileage wise since your last actual service Question
If its not coming up to 16k or 12 months then its NOT due, wait until it is due, book it in and get them to update/clear/rectify the early notification when they do the service at the Correct time/mileage
If you dont have any paperwork to confirm last service you can always check it online with your chassis number
if you book it in early for a service I am sure the dealership with relieve you of your £££ early as well Rolling Eyes
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #590457 Fri Nov 15 2019 3:41pm
Hugh Haddow
Thanks everyone. I’m now convinced it is a service indicator fault. The ‘service due’ milage is increasing????
It was serviced at 31600 miles. About four months ago.
Booked in with the dealership.
Cheers. Hugh
Post #590486 Sat Nov 16 2019 1:15pm
