![]() | Home > Technical > Instrument panel mileage / trip display - no backlight |
Ians63 Member Since: 03 Sep 2019 Location: NE Scotland Posts: 20 ![]() ![]() ![]() |
As per title - the right hand lcd (mileage/trip) does not illuminate. Everything else is ok. Any ideas? |
2006 |
Has it had the issue with the can bus sorted in the past? It may be worth checking the connections on the back. You could also try banging the dash above the binnacle you see if you can get anything to happen. 2019 5.0 SC SVA (Current)
Only had the car a month so I don’t know any of its history- I’ll try the “technical tap” approach first. RRS 2006
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
Ah the Land Rover cure all the 4lb lump hammer if you know what to hit and the 9lb lump hammer if you know where to hit it ![]() Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6 1973 Land Rover Series 3 110 safari Gone but not forgotten 1990 Discovery 200Tdi Gone thank god 1996 Discovery 300Tdi sadly missed 2003 Discovery TD5 Gone to LR heaven 2004 Discovery TD5 Gone to Aberdeen hope it likes it there 2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling Think I see a pattern here |
It’s not a cure but if you get some flashes of light you know you have a contact issue. It’s been used to successfully diagnose cluster issues in the past. It’s also a good way to relieve some frustration!! 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
I like that, I’ll try and remember it for next time. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Update - it’s working now. No technical tap required. I’ll keep an eye on it and hopefully it’s not a sign of further impending doom. RRS 2006
