![]() | Home > General (L494) > Heating & Ventilation Recirc Flap Has Been Broken |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Just manually pulled the cover down to close it then pressed recirc, it was trying bit by bit to go up but got there, i pulled it down again and tried it again, pressed recirc then this time it opened perfectly, maybe was jammed, will have a look again tomorrow to see if it will close on its own too? |
Seems like its sticking when it opens, its struggling to close on its own, access is very limited so cant really see why |
Ok, can now get the flap to open on command from the recirc button but it only opens half way, but then can get it to close again on command, sounds like its jamming or maybe the motor on the side that operates the door, anyone know? |
