Home > Faults & Fixes > Parking sensors not working
Wayneclarke
Both front and back sensors have stopped working I get a long beep then the flashing light. Had the car plugged in and this is what came up. Anyone got any ideas? Control
module maybe???
Post #589496 Wed Oct 30 2019 3:35pm
Brit Plumber
What year?
If it’s the same fault on front and rear I’d suggest checking the fuse first and then power to the module and go from there. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589497 Wed Oct 30 2019 4:10pm
Wayneclarke
It's a 2006 I will try and locate the fuse to check there
Post #589499 Wed Oct 30 2019 4:27pm
Eaters
Have a quick look here:
https://www.rrsport.co.uk/forum/topic48459...ng+sensors
Not necessarily your issue but I believe there are known problems with the loom around the rear sensors - so if you get that far, this may help Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #589535 Thu Oct 31 2019 10:46am
Wayneclarke
That's a great post cheers wish the weather was a bit warmer
Post #589556 Thu Oct 31 2019 1:41pm
Eaters
Laughing Robin
Gone:
MGZTT 190 2.5
Post #589558 Thu Oct 31 2019 1:49pm
Wayneclarke
quick update. car has now been repaired the parking module had broken down so replaced that and all working fine now.
Post #590271 Mon Nov 11 2019 8:21pm
Wayneclarke
Guess what guys? , sensors have stopped working again, long beep and flashing light. Banging Head
Post #591826 Fri Dec 13 2019 5:58am
Eaters
Shocked Robin
Gone:
MGZTT 190 2.5
Post #591831 Fri Dec 13 2019 7:49am
Wayneclarke
So car went back in today and was reset as it had lost communication, worked fine for a few hours then it's gone again. These are the fault codes that have come up! Does anyone have an idea please?
Post #591929 Mon Dec 16 2019 5:42pm
