![]() | Home > My Range Rover Sport > Hi from a new owner |
Hi & welcome,is yours a RRS1 or RRS2 as 2013 was the changer. Andy.
Joeym_rrs Member Since: 04 Oct 2019 Location: Liverpool Posts: 7 ![]() ![]() ![]() |
Sorry its a RRS1 last of the old ones
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
Good choice |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Welcome and congratulations on the purchase. One thing I would do is if its still got the original locking wheel nuts fitted remove and replace them, they can fail and when they do it can become problematic trying get them off. |
Is it the 3.0 SDV6? 2019 5.0 SC SVA (Current)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Definitely worth getting the gearbox flushed now. Belts due at next service I would guess.
It will be if it’s a my13,they didn’t do the V8 after 2010. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Front end looks low |
Simple check for ride height with a tape measure
Ill have a look at the measurements given in another comment but its in access mode here. Goes up to normal height fine but ill check |
Cool ill look into it in the next couple of months. It seems smooth enough but I have read its worth getting done for peace of mind |
Think about fitting a new oil pump when the belts and pulleys are bring changed. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Just measured...in access height its around 410-420mm. In normal its 460mm and off road height 500-510 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Not far out for normal ride height.
