Home > General > RRS L320/2006 V8 High beam
jordan781
Bulgaria 2006 Range Rover Sport TDV8 HSE Bonatti Grey
Hello all i have a problem with the high beam on the right headlamp does not turn on when i give command from the control lever the left lights up without a problem but the right one refuses to light, i checked all the fuses and found no problem if anyone encountered this please help.
Post #587581 Thu Sep 26 2019 4:13am
Silly question: have you checked the bulb? 2012 SDV6 - it's missing a couple of cylinders
Post #587593 Thu Sep 26 2019 8:25am
two things should happen.
The H7 halogen bulb should come on.
THe HID flap should click and top half light up
If neither of these things happen, is it probably.
1) A wiring fault between headlight and fusebox inside.
2) fusebox/CJB fault (expensive)
If the issue is 2. I could come up with cheaper solutions!
Post #587603 Thu Sep 26 2019 11:07am
jordan781
I don't think it's a stupid question I started by checking first from the poison that the bulb was healthy turned out to be healthy then I checked the installation it is also a healthy fuse for this light missing but there is a driver I found in the dashboard I will now replace it and I think I will is fine.
Post #587992 Fri Oct 04 2019 4:42am
Brit Plumber
Can’t quite see the diagram but I think you’re circling a part this is part of the CJB and will probably require replacement as a whole unit. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #588000 Fri Oct 04 2019 7:58am
