![]() | Home > Technical > Engine Oil Level Monitor System Fault |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
We've changed a few of the oil level sensors. It's an engine out job as it is located in the sump and can't be accessed in situ.
Elbitrevnoc Member Since: 30 Oct 2013 Location: Berkshire Posts: 17 ![]() ![]() |
Hi Joe,
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Resurrecting an old post, was there any resolution to this issue? Got the exact same issue.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Underlying fault appears to be oil ingress into the wiring loom inside the sump, same as Td5 suffered from
How critical is this? Can I still rely on the electronic dipstick showing a true reading?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
If you've only had it a month then the selling dealer is likely responsible anyway under consumer protection laws. 2012 SDV6 - it's missing a couple of cylinders
Maybe a good idea the check the external connector on the side of the sump for damage or water ingress. Water is a conductor whereas oil is an insulator.
Thanks to all for your input, going in to an indy near me on Friday. Will let you know the outcome both technically and financially. RRS HSE Dynamic SDV6 2014
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 ![]() ![]() |
Only had my 2014 RRS 10 days and been unable to get oil reading just says not available. IID shows below.
Sensor, wiring, plug, harness. Take your pick.
Thanks Joe for that.
Fingers crossed for my diagnostic tomorrow. Good tip from Oval, shame you are not closer.
Plan is to get belts done but 7 years takes me to next November. But if it was engine out and belts could just be put on simply and easily with next to no additional labor costs it would be a wise decision. I just don't know the answer to that though. |
The recommended time for belts to be changed is the maximum time between changes.
