Davidno64
Cranks Ange Position Sensor, TDV8 | |
Hi,
Looking for details on both Crank Position Sensor & Cam Position Sensor.
I have a complex and ongoing issue with my TDV8 and cannot easily find some details. Location of these sensors. Firstly does anyone know where on engine are they located and any pictures.
What is involved in testing these sensors, as my scanner does not seem to monitor these sensors?
What is involved in replacing/setting up these sensors. Specifically Crank Position Sensor.
(I am suspect of Crank Position sensor. Long story....New PCM, Injectors, Fuel lines, H.P Fuel pump, etc, Now car runs but Smokes. (See my other Post's) Slowly getting there but Injector #4 is over-fueling. Trim at 1400, while others at about 600+). Now car idles runs rough at low Rev's. Recently noticed misfiring while injectors are in Trim mode. I am suspect now of Crank Position Sensor being faulty & intermittent)).
Any details on these sensors will be welcomed. Where are they located and procedure to change.
Thanks in advance.
Tue Sep 17 2019 2:51pm |
