Home > Faults & Fixes > Air bag makes a bang...
Boots
England 2005 Range Rover Sport Supercharged Baltic Blue
After driving a short distance the O/S/R airbag pops like a loud crisp packet. Suspension goes up and down on the height adjustment switch. Its a 2006 supercharged sport. Can just the airbag be replaced ? Banging Head
Post #585881 Mon Aug 26 2019 3:19pm
Yes, the bag can be changed separately if you're happy to keep the old damper. 2012 SDV6 - it's missing a couple of cylinders
Post #585883 Mon Aug 26 2019 3:59pm
Boots
Off to Spain Friday night boat ….which is quickest ? change bag or both struts
Post #585885 Mon Aug 26 2019 4:11pm
knwatkins
If your dampers are 13 years old, it's probably worth replacing the whole unit, including the damper. Kev
Post #585889 Mon Aug 26 2019 6:24pm
Brit Plumber
/\/\ As Kev said, and change both as the other won’t be far behind and your handling will improve./\/\ 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585971 Wed Aug 28 2019 3:15pm
Boots
First time ever I listened and done as advised. Changed both complete units....Thank you gentlemen.
Post #585975 Wed Aug 28 2019 5:05pm
knwatkins
No problem. That's what the forum's about Wink
You may as well do the fronts now too Whistle Kev
Post #585976 Wed Aug 28 2019 6:24pm
Boots
Two weeks in a car with a just saying wife....think I would be pushing my luck, no life, to mention it.
Post #585978 Wed Aug 28 2019 6:40pm
